Feature requests for 1 and 2 MRCC Units
1. Is it possible for MRCC clock to pickup an external clock, then assign that out to inputs in the clock section? This would allow us to separate clock signal from other midi signals.
2. Can you increase the number of routings/mod assignments, when you have a lot of devices and start to filter out clock/start stop on them while having lots of devices receiving clock/notes, you can reach the current threshold fairly consistently.
3. Is it possible to add all input/output destinations to the port filter sections, it only covers about 80% of the destinations.
4. Are you still investigating adding 4 inputs and 4 outputs per USB port? That would be great and useful for WIDI by CME and other devices.
5. When you have two MRCC Units, midi notes/clock/cc are not reflected on the receiving second device which makes it difficult to troubleshoot if you are not sure the final device is receiving a note/clock etc.
6. Can you allow two MRCC units to share input/ouput naming?
7. Can you allow a save on one device to trigger a save on a second MRCC?
On request 1. maybe if we could assign a cc to control the start stop buttons, MRCC clock could be used as the system clock?
