I can only route the PC port to two outputs
Hi, I just reset my MRCC after not using it for some time and I can't figure out how to set it up now. Everything is fine except the USB PC port. For some reason, it only allows two outputs total across all virtual USB cables. So I can set PC01 to eg outputs 4 and 5, or I can set PC04 to output 2 and PC08 to output 7, and then I just can't add any more outputs, the blue lights don't light up. What am I doing wrong? It used to work prior to loading the factory preset.
Edit: okay, I may have hit a connection limit. Maybe I have too many inputs and outputs. Is there a hard limit on concurrent connections? I can't find any.
There may be others, but this thread discussed it: https://conductivelabs.com/forum/showthr...p?tid=1798
