Bricked MRCC after latest firmware update.
I followed the instructions here on the site. using the links therein
I tried the update with my Macbook, which only has three USBC ports. I did the initial using a hub. Then I removed the hub. still nothing
when I pressed the firmware button everything went black.
I made sure and used the correct MRCC firmware available on the update page.
I have tried many different cables usbc usb b to usbc
I have tried my PC with all of the same cables including long and short.
when I power on the MRCC the PC LED flashes briefly
Factory reset does nothing
I have tried earlier versions of firmware. No Joy
Thoughts?
Chad,
Did you see this post? Hopefully yours is something similar and you get a resolution.
https://conductivelabs.com/forum/showthr...p?tid=2245
(04-29-2024, 11:28 AM)vizulefllry Wrote: Chad,
I did, and I have scoured the forums for resolutions.  I have seen several similar situations but none of their solutions addressed them. Thank you so much for sharing though I love this community.
