10-31-2024, 05:58 AM
Hello
Thanks for a great jamming toy
Regarding Pad
It would be a great advantage if rhythm could control pad strum 1. Pattern can control together with rhythm the other strummers.
The Range and Spread encoder
After spread 6 it would be nice if Pattern 1-40 came in and pattern length could be controlled with Range. I don't know if it is possible to program it by adding the Pattern function.
The Position and Strum encoder
After strum 7 continue with Rhythm and add a third function on the encoder which becomes rhythm length. It all depends on whether it is possible to add after without it taking up too much space in the programming
Regarding drones.
Notes
It would be a great asset if you could get a fourth tone (the 4th)
When you then modulate it by going between 4th and 5th…..
Trigger
After the last trigger switch to rhytm
Is it possible to have four functions on an encoder, like that, you can insert rhythm length there?
BR
TantoDanne
Regarding Pad
Regarding drones.
Notes
Trigger
BR
TantoDanne
