Midi mystery: NDLR with a Behringer Edge.
Has anyone used their ? I use the NDLR as a controller hub for 3 - 4 hardware synths and have had no issues connecting them with 5-pin midi.
However the Edge behaves oddly. It works as intended with other midi gear like keyboards and as a slave for other hardware synths.
When I connect it to the NDLR for motif or drone duty it will trig once but then not trig again. If I trig the Edge manually with the dedicated trig button or by external cv though it's patchbay it will play the motif as intended until I remove the trig source. Almost as if the NDLR does not send sufficient velocity to it. NDLR CC value is set to 127 and 75% and changing those does not help.
A very specific issue and not very important, but it annoys me that I don't understand why it behaves like this.
I can't think of any setting on the NDLR which would cause this, but just in case, I would try doing a firmware update on each device if applicable and seeing if that solves the issue.
you have this Velocity 127 and Vel low 75% fix only when you run the MOTIF in ACCENT = MOT VEL (Button 8). Please check.
Is anything plugged to the MIDI IN of the NDLR? Maybe you can try with the B Edge on another Channel?
