Difficulty Routing Multiple MIDI Channels through MRCC on Mac
Sad
Hello
I am currently using the MRCC (MIDI Router Control Center) with my Mac to route multiple MIDI channels between various devices & software but I am running into a problem where certain channels aren’t being routed correctly. Sad
Specifically; MIDI signals are sometimes being dropped or mixed between devices; leading to unexpected behavior in my DAW and external MIDI hardware. I have checked https://conductivelabs.com/forum/forumdi...hp?fid=23/splunk reference guide but still need advice .
I have checked my connections and made sure all devices are recognized; but the issue persists. Has anyone experienced similar issues with routing multiple MIDI channels, especially on Mac? Sad
Any advice would be greatly appreciated!
Thank you ! Smile
Can you please elaborate on this for me? Is the issue happening intermittently where it will occur and then fix itself within a single boot cycle (I mean does it change only when you reboot or does it exhibit multiple states within the same use session?) Which version of the FW are you running? It may be a good idea to reach out to me at Support@Conductivelabs.com and we can talk it over in more detail.
