12-15-2024, 04:50 PM
(This post was last modified: 12-15-2024, 04:51 PM by DigitalAnalogDaily.)
Over the last few months of owning the MRCC, I've found that it frequently requires restarting both the hardware connected and the unit. This tends to be required more for hardware connected via USB but happens with DIN connections as well.
Hardware list:
Hydrasynth - 5-pin - In/Out
Elektron Digitakt 2 - 5-pin - In only
Elektron Syntakt - 5-pin - In Only
Elektron Octatrack - 5-pin - In/Out
Waldorf Iridium Desktop - trs(mrcc)/5-pin(Iridium) - In/Out
Arturia Keystep Pro - USB - In/Out
Windows 11 - USB PC Main - In/Out
I've had to turn off the MRCC several times because the signal is not stopping. This could be due to a lack of experience and understanding, which is why I'm coming here to see if others have similar issues. If so, is restarting things just the normal path to enlightenment?
Joshua
Hardware list:
Joshua
