12-18-2018, 08:37 AM
I want higher notes from motif to be generated with lover velocity values. ( I know I should do this on the synth mod matrix but not all have that option) Do you think this could work:
1. Route "MIDI B out" to "MIDI A in" via smart MIDI merge (B channel 1 to A channel 15 control channel)
2. Set modulation source to Velocity
3. Set modulation destination to CC of velocity (I don’t think that is available, there is no CC and velocity is NOT exposed as destination)
4. Invert the MOD range (I don’t think this is possible either)
5. Now the higher notes are played with lover velocity,
Is this idea too crazy ? looping MIDI B to MIDI A ?
I see bunch of scenarios to “tweak" the MOTIF results like this. In the worst case add MOTIF rhythm/tune output as modulation source and perhaps ability to reverse the range on on destination. Then I can have any CC to be tweaked by note or velocity.
While on this, do you think it would make sense to add to Humanization Note length or Note nudging ? Slight variation would make the results more organic. (I’m constantly changing decay on percussive patches to use S&H or random)
I have to stop with these posts b/c there just so much work you guys have to do before the year ends ... and I’m bugging you with these features right ?
I'll get with Steve to review it and see if there's some crazy way to achieve what you are proposing, but I don't think there is. Interesting idea looping the Out to In... By the way, there is a velocity to CC (41) feature made for Volca FM that you can enable in System menu 3.
