		05-21-2025, 02:44 AM
(This post was last modified: 05-21-2025, 02:45 AM by MKS30.)
		Using 1.1.086 I cannot get either of these note ranges to work (Mode 2 - white and black KB ctrl)
page 59 - C#3 - D#4
page 32 - C#5 - D#6
Incoming notes (ch15) NDLR Cntl (ch15)
8
		05-25-2025, 10:05 PM
(This post was last modified: 05-25-2025, 10:18 PM by Jesse Johannesen.)
		I just plugged in a MIDI controller and pressed notes until it worked, the correct range is C#2 - D#3. I'll see if I can get Steve to fix it in the manual. I recommend sending me an email at Support@conductivelabs.com if you're looking for more timely support rather than reporting your post. I check that email multiple times per day and it's much harder for something to slip past me there.
Oh and it's worth mentioning that when you do press one of those black keys, nothing changes until you then press a white key, at which point the chord degree and chord type change at to the newly selected combination.
