06-13-2025, 11:36 AM
I have an ERAE Touch V1 plugged into USB Port A, and a Teenage Engineering OP-XY plugged into port D. By default the OP-XY uses channels 1-8, so on the ERAE Touch I set up a keygrid, assign it to channel of whatever I want to play on the OP-XY (or other devices), and that's that. Pretty easy.
The issue is that the OP-XY does very odd things when you send it note data from channels that are not assigned to a track in the project settings. I want to send notes on channel 13 to a Roland Juno, and when they hit the OP-XY the thing bugs out and plays sequences at random. Ditto for most other channels. I already flagged this with TE, who knows if they will get back to me and help. I am operating under the assumption that this is either some quirky weird thing they think is cool and therefor not a bug, or it's something so minor they may not ever get around to fixing it.
With other MIDI routers, like the CME U4 MIDI WC, it was very easy to prevent all MIDI data on certain channels from ever hitting the OP-XY. I cannot figure out for the life of me how to do this on the MRCC. I checked out the Channel Mapping Modifier, and that doesn't seem like what I need because I do not want data from channels 9-16 to be re-routed to different channels. I want it completely gone. I also checked out this new-ish "C-P1" modifier and I don't think that will help considering I (a) need multiple channels of data to go to the OP-XY, and (b) it's using a USB port, not a 5-pin port, so the numbering system involved seems incompatible.
I can grab the CME U4 and integrate it into this setup to accomplish this one task, but I would rather work with what is already in front of me.
Any suggestions?
Any suggestions?
