AC power adapter for NDLR
Hi, I did a search but could not find anything on this.
If anyone is using an AC power adapter with USB for NDLR please let me know the spec or grateful if you post a link, eg, amazon or the website you purchased it from.
Thanks much!
H
The NDLR will work with pretty much any USB power source. Its a USB 2.0 device and uses less than 100mA, so you should just use a decent quality USB adapter. I've had good luck with Anker and Aukey brand USB chargers, but if you have any old USB adapter around the house it should be fine.
