Oh man that video is glorious. Great work on this dude.
Threads: 11
I didn’t have time to look at the turning all parts on and off with a single cc yesterday. Not sure how difficult to do yet. In the mean time I was wondering does TouchOSC have multiple cc messages on a single button press?
Feel free to PM me.
Thanks,
Steve
02-06-2020, 12:21 PM
(This post was last modified: 02-06-2020, 12:40 PM by Scotty_123.)
Bug Reports and Documentation Errata for Firmware beta 1.064 and Manual 1.7
Thanks Steve... to the best of my knowledge you can't assign multiple CCs to a single button press. I will look into this further though to be certain.. Also I got your email that you sent today and responded. I am also posting the bug reporting and documentation errata that I found in my testing to this point. I am actively updating my templates with the new features and CCs that you enabled... I hope that this is helpful.
Motif 2 Midi Port is mapped to CC 24 ... documentation says CC 26
Send Midi Stop Start Continue on CC 58 has a range of 0 -9 - Documentation says 0 -8
Documentation should indicate as follows:
Value of 1 = All Ports Value of 2 = No Ports (missing from documentation ) Value of 3,4,5,6, = USB 1 - 4 , Value of 7 =
MIDI A, Value of 8 - MIDI B, Value of 9 = MIDI A & B
NEW CC ISSUES
Load Chord Sequence ... Chord Sequence Load 1 is Broken AND no option to Load 0 Chord Sequence
Using CC 89 entering value of 1 will not Load Sequence 1 ( Sequence 2, 3 , 4 and 5 do load as expected).
IMPORTANT : There is no way to LOAD Chord Sequence 0 which is important if you don't want to be in Chord Play mode.
mode... Solution? perhaps extend CC range to 1 to 6 and add LOAD 0 as option with CC 89 Value 0 + fix broken Load 1 sequence.
* Previously Unreported Issue
Updating Motif 2 Pattern length via CC 44 doesn't update the numerical value in yellow on the ndlr hardware when motif
2 screen is selected. The graphical representation updates correctly and the pattern length appears to be selected
correctly and playing properly. It is just the numerical value which doesn't update its value.. Motif 1 Pattern Length value updates as expected. To be clear
I am referring to the numerical value in yellow that appears on the line where accents are displayed with 0...0.... on the Motif 2 page on the hardware.
CONFIRMED FIXES - (fantastic!)
All Midi Port and Channel Settings are confirmed to be working
All Menu Corruption appears to be solved when controlling via CCs
I haven't tested the other fixes that are mentioned in the documentation but will confirm later today when I get to that point. I am actively updating my Templates with the new features (CCs) that you have enabled etc. Also I will test your new CC for Toggle All Parts which you sent via email which I really appreciate. Thanks!
Video Chat?
If you can suggest a time and that works for you via Messenger Video (preferred) or Skype .. I'll organize my thoughts. It shouldn't take more than 5- 10 minutes to connect at most. If you can give me your time zone as well .. I am in southern Ontario , Canada on Eastern Standard Time.
Also confirming that the issue "When adjusting clock in values using in values 0 to 7 on CC 68 - the clock in updates perfectly but it also modifies the MOTIF 1 values on menu page 1/3"
This has been resolved with the menu artifact solutions that you implemented... it was part of the same problem that you have addressed in firmware Firmware beta 1.064... Very happy that you have fixed that issue. I was thinking that could be tricky one to squash.. Bravo!
