I tried to control the entire NDLR with Pyramid by Squarp. The problem is that NDLR doesn’t respond well when lots of CCs are coming in simultaneously. Some of messages are skipped in an unpredictable way. It is very frustrating...
What’s your experience in controlling NDLR with external MIDI devices?
Best regards,
GABI
/9 TUPLE
7
Hey Gabi, I'd love to see if I can help you out with this. Let's start out with a little more info about your setup:
Is the pyramid going straight into the NDLR?
How many CCs are you sending and what are you controlling with them?
give me a little more info about the hardware setup being controlled as well.
I'll probably have you start by simplifying what you're trying to do and add stuff back in until we see where it stops working. I don't have a pyramid on my end but I do have an octatrack and hopefully I can see about trying to reproduce your issue.
Let me know your setup and we can go from there.
hi i got also massiv problems with pyramid and ndlr.
ndlr stand a lone works nice but if i bring it to the pyramid because pyramid is the brain of all.
i got heavy midi messages from the ndlr. (overload cc etc)
i tried a lot of settings ( echo off / omni mode because i use it for the other synths)
there is a huge midi echo and i cant find that. maybe u can help me ?
one question, is it possible to deactivate all the CC messages was send by ndlr? i just want to use the note on-/off .
thank you.
