02-10-2019, 03:35 AM
hi, yesterday I've received my ndlr and started to use it with an Ultranova.
I have a 1 rack AE modular (backed on KickStarter as the ndlr), but I don't know how to use it with the ndlr.
Do I need a "cv to midi" or something like that?
I'm not a professional user and ndlr and Ae modular are the first hardware of this kind that I own
Thanks in advance for your help.
Andrea
3
I suppose the AE Modular has a way to configure the MIDI channel it is listening to? Otherwise, you can try all of the MIDI channels while a NDLR motif is playing.
these are the midi spec of the AE:
the MIDI in on the MASTER module of AE modular receives either on MIDI channel 1 (switch in left position) or Omni/all channels (switch in right position).
The MIDI note range of AE starts at 24 = 0V
So I've connected the NDLR Midi out b to the AE; set MOTIF2 midi on 1MIDIB but nothing happened…
Any suggestion?
Thanks
Andrea
3
I would suggest starting out with the AE set for Omni, so whatever comes in can play. I assume you configured The NDLR Motif 2 for MIDIB, but you can also try "1 All" so motif 2 goes out on all ports.
Can you make AE play with a MIDI keyboard?
>>you can also try "1 All" so motif 2 goes out on all ports>> I've tried and nothing happened.
>>Can you make AE play with a MIDI keyboard>> Not yet tried, I'll do.
Thanks
now it works: it was necessary to ad a patch configuration in the ae.
Thanks again.
Andrea
