10-15-2021, 11:58 AM
I get confused with how the manual describes "hosts" In & Out for USB and I need a very simple connection
I work with Cubase
In Cubase I've setup my Prophet10 as master keyboard/ input controller, which works fine
I also have a MOOG Subharmonicon and the right (type A) midi trs cable
Directly from the Prophet10 out to the Subharmonicon midi works fine, I can play
However, having setup the MRCC, connected via USB to my DAW, Cubase sees 16 MRCC ports (which I assume correspond to the MRCC + Extender)
The Extender mode has been set to +5 extender
The Subharmonicon is in Extender port 1 (I assume this is then MRCC virtual port 13?)
I press the left "PC" button (under the USB device port)
I press the Y knob and press out one (turns yellow)
When I now select MRCC13 in Cubase as a midi output, it DOESN'T trigger the Subharmonicon
Neither do I see midi in activity on the OLED screen
Where am I going wrong?
I just need a very basic patch from a virtual DAW port to a physical midi out. Can't seem to do it.
Please advise?
I work with Cubase
Please advise?
