NDLR USB not recognized by iConnectivity MIDI4+ host
#41
(04-23-2023, 02:35 PM)Jesse Johannesen Wrote: I haven't had any updates from the Iconnectivity team yet as to their progress with the NDLR host recognition, so I would assume it's still a "no" at this point, but I can shoot out a message to see what the status is. You may want to reach out to them as well.
FWIW, the latest (Version: 2.1.0) firmware for mioXL/XM - https://cdn.iconnectivity.com/firmware/n..._notes.txt states:
Date: 2023-08-21
1. Added support for hosting Roland devices (MIDI only, not audio) that are not using class compliant USB MIDI descriptors.
---8<---
After this upgrade, the NDLR appeared (as four separate USB devices/ports) in my mio, from which it was being powered, but connected by DIN.
Still DIN-connected, and USB not yet tested, but might be a ray of hope if it actually works.  I don't know whether the latest NDLR patch (v1.1.086 for me) changes anything for folks who have non-mio iConnectivity devices, like the MIDI4+ mentioned by the OP in this thread.
There's another thread on this in the MIDI connectivity subforum, so I'll crosspost there too.
HTH,
auto
Yup, with NDLR 1.1.079 + mioXL with 2.1.0, all four NDLR USB ports lighting up in MIDI-OX, via RTP-MIDI (I don't use USB for MIDI).  All looks good.
Same after applying the NDLR 1.1.086 patch.
Crossposting as previously; seems like this is a fix (and I've gained a precious MIDI in, too).
Smile
[happier] auto
Great news! We didn't change anything with The NDLR USB client, so technically it shouldn't matter which NDLR FW it is, but having a recent version is good for other things.
(11-28-2023, 01:29 PM)Darryl Wrote: Great news! We didn't change anything with The NDLR USB client, so technically it shouldn't matter which NDLR FW it is, but having a recent version is good for other things.
The iConnectAudio4+ does not recognise the NDLR Host Port and firmware was last updated in 2018, users report the MioXL issue is resolved.since v2.1
I'll write and request a fix, but need to present some clues.
in the MioXL release notes:
v2.1 : 'Fixed a problem with USB host driver that was preventing some devices from enumerating' (I'm using a Mac, so not sure if this is relevant?)
v2.2.3: 'Added support for hosting USB-MIDI devices with a product ID of 0x0000'
Regarding 'product ID of 0x0000' does that relate to the NDLR serial number, mine reports as 000 0000 0000 ?
I think Product ID and Serial Number are separate things in this case. I believe Product ID is a number that (along with a vendor ID) uniquely identifies the USB device so the computer knows what it is when it plugs it in. I don't remember what numbers the NDLR is set to, but I am pretty sure it's not 0x0000. I think the 2.1 update is probably the one that addressed the issue.
10 Guest(s)
