03-11-2021, 10:24 AM
(This post was last modified: 03-11-2021, 10:25 AM by chrisharrisx.)
Hello all, just discovered the MRCC and it looks like it will be a very useful addition to my current setup. Looking through the draft manual I see that there are presets that are saved to the SD card, but I didn't see any info on whether it's possible to switch presets via incoming MIDI.
A basic use-case I'm imagining is a sequence coming in on one port, routed to a couple of synths via two output ports, then being able to change the input to output mapping (i.e. to two other synths) rhythmically using something like a program change message...
