Switch between AKAI MPC ONE and PC as main DAW (sequencer, clock)
#11
(07-31-2023, 05:14 AM)oldgearguy Wrote: FWIW,  I have a USB switch box connected to a controller keyboard.  The two outputs from the USB switcher go to the computer and the MRCC.  I had to go through a few different switchers before I found one that worked in my setup
yes, you are right.
i bought this one and now i can switch between two DAW´s
UGREEN USB Switch 2PC
yes, you are right.
what I wanted to say. apparently it is important to use a usb 2.0 controller. the usb switches that can also use usb 3.0 somehow cause problems when switching or recognizing midi.
