Routing mute / solo groups
Mute / solo for routings should work in relation to a single input port. They should be remotely controllable, possibly via note on/off messages.
This would be useful for example when having a single "universal controller" input (i.e. Faderfox EC4, Electra One, or simply a master keyboard controller) with configurations for multiple devices with overlapping midi channels that are spread across multiple outputs, where the channels are obviously not overlapping on a single output (i.e. 50 channels on 4 outs, with most of them being utilized on 3 or 4 ports, each for a different device).
So when having devices on 4 outputs and having all those outputs mapped to the controller input, it would be possible to remotely from the controller itself mute the routings to the outputs 1-3 and only control devices on output 4 until deciding it's time to control devices on output 2 and soloing that routing.
I realize this could be accomplished by manually creating and removing routings and / or by having multiple presets and toggling between them, but for my case, that seems much more complicated then being able to solo / mute routings remotely ideally while having a visual feedback on the MRCC LEDs.
Scratch the above, here is a better version.
Similarly to port filtering screens, I imagine two new screens - one for routing mute groups and one for routing solo groups.
There would be 4 groups in each.
The screens would have a row for each routing with 4 mute / solo group checkboxes.
These mute / solo configurations would be toggle controllable via MIDI CCs.
