Threads: 3
03-11-2025, 06:09 PM
(This post was last modified: 03-11-2025, 06:09 PM by IndieMurph.)
I was reading thru the MRCC manual and came across a reference to a Remote7 (R7) but I have no idea what that is. I checked the products page. Nothing there. Eventually, I will be interested in connecting two MRCCs for additional MIDI routing to more synths.
5
The Remote 7 is an expander for the MRCC which allows you to either copy the first 5 ports output to the DIN outputs of the device (with 2 ports copied to both DIN and 3.5mm, hence 7). It is also possible to send individual routings to the 5 output targets by changing a setting and using the remote (Y guy) routing button on the MRCC.
If you want to connect 2 MRCCs you can with the same shielded cat 6 cable, and you can even use a special splitter to route to both the second MRCC as well as copying ports 1-5 to the Remote 7. We have a bunch of the splitters, and if you buy 2 MRCCs and a Remote 7, hit me up (at support@Conductivelabs.com) and we will chuck one of the splitters in with the order for free.
""It is also possible to send individual routings to the 5 output targets by changing a setting and using the remote (Y guy) routing button on the MRCC.""
Where would one go about finding this documented? Or the setting process?
I have been unable to find it.
You can switch the mode for Remote 7 outputs from "Copy 1-5" to "Remote 1-5" on the Settings screen Page 2/4. It's the last parameter on that page.
In the Quick Start Guide, it is covered under "MRCC Remote 7 Port Extender". In the User Guide, see the section "Settings screen page", R7 Ports.
Also see the "Remote Routing" section on page 14, but it's short; hold the Remote routing button (with the Y to the left of the navigation knob) and select outputs. When the Remote button is pressed, the outputs that are routable will glow yellow. With a Remote 7 in "Remote 1-5" mode, and attached with the appropriate Ethernet cable, there will be 5 yellow lights, and if there are two MRCC's attached to each other, there will be 12 yellow lights.
