Some questions before buying
Hi all.
Does the MRCC have some sort of backup/restore functionality, by means of which I could save the configuration to a computer (for example via SysEx, or with a proprietary app)?
Am I right understanding that the maximum number of MIDI outputs is limited to 17 (12 from the MRCC and 5 from the Remote7)?
TIA
There is not a feature to export saved states, but they are held on an MicroSD card on the device so you could back them up manually. It would require removing one of the end cheeks.
There are outputs as follows:
4x USB A outs, A-D
10x DIN outs 1-10
2x 3.5mm 11-12
12x USB B Virtual ports 1-12
5x Remote 7 ports available with expander
(Yesterday, 06:54 AM)Jesse Johannesen Wrote: There is not a feature to export saved states, but they are held on an MicroSD card on the device so you could back them up manually. It would require removing one of the end cheeks.
4x  USB A outs, A-D
10x DIN outs 1-10
2x  3.5mm 11-12
Thanks. In fact I was referring to DIN5 MIDI (or 3.5mm to MIDI connections). Therefore a total of 12+5 maximum DIN5 MIDI, right?!
